Fluent
I am getting AMG solver: Temperature error. I would like to know how this can be solved. Actually, I adjusted my solution controls to 50%,[pressure,Density,Body forces,Momentum, Energy] but still I get the same error.
Re: Fluent
Sironda, When I use the periodic flow,and the flow direction is wrong ,I will get this information,you should check the flow direction if you use periodic flow.
