February 13, 2003, 19:19 |
Help-UDF
Hi, Sorry to be a pain in the neck..but i need help to set my inlet boundary condition as function of velocity profile. Basically my model has a depth of 30mm and i need to set the inlet condition as a UDF function in C prog. The velocity at 4 different points are..
depth 24mm - 0.23m/s depth 18mm - 0.28m/s depth 12mm - 0.33m/s depth 6mm - 0.38m/s Can someone pls draft me the C prog for this function, i know its only a few lines but i am really bad at C prog. Pls..thanking you in advance, i really appreciate it |
February 14, 2003, 06:33 |
Re: Help-UDF
hello ravi, the UDF will not be in the C language syntax. It is having separate syntax. U can write ur own UDF program by following the example given in fluent help. I mean the way to write a UDF. ask me if u not clear.. prasanth
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
