Convergence Problem..!!
Old   February 17, 2003, 20:58
Default Convergence Problem..!!
Amid Naz
Hi all,
I'm using coupled solver to solve 3-D swirler flow..Inviscid solution with about 1.5M tetrahedral cells has converged. Viscous solution failed to converge specially the energy and the continuity residuals which became almost constant around the value 2.0x10E-03...Any advice is highly appreciated..
Amid
Old   February 21, 2003, 16:27
Default Re: Convergence Problem..!!
RR
Try lowering the convergence parameters and try using different types of discretization schemes. Probabaly that will work.
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
