-   -   How to put human in a room? (http://www.cfd-online.com/Forums/fluent/30958-how-put-human-room.html)
ah_Keng February 17, 2003 22:33
If I want to put a human in a room, how should I do it?
What type of boundary conditions should i set?
thanks
zhhuang February 18, 2003 00:37
Re: How to put human in a room?
If you use the icem-cfd,you can use the Autohex to finish it,it's very easy!
ah_Keng February 18, 2003 03:16
what is icem-cfd?
I am using Fluent 5.3
janine February 19, 2003 11:23
What exactly do you want a human in the room for??
Are you measuring heat transfere ??
it could be a WALL ...it depends on what you want to evaluate
ah_Keng February 20, 2003 01:03
I am trying to find an optimum supply temperature for a lecture hall in different situations.
Such as, optimum supply temperature when there are 100 occupants inside....
Right now, my solution is set the boundary conditions (for human) to wall, but I dont know what kinda "wall" should I set?
Do I need to add Heat generation rate and other stuff???
Thanks in advance.
ps. I am using Fluent 5.3
janine February 20, 2003 05:05
Im no really fammiliar with Fluent 5., but a you can use the wall with the temperarute option and there you can specify the temperature óf the human and the heat generation rate.
Amir Khanlou February 20, 2003 11:34
Hi you can use Kansas State University model for the human body heat transfer model. KSU have a very precise model for heat transfer study on human body. if you search in WWW you'll probably find some papers related to them. if you couldn't find something let me know to introduce you some useful paper. Regards Amir
