February 17, 2003, 22:33 |
How to put human in a room?
If I want to put a human in a room, how should I do it?
What type of boundary conditions should i set? thanks |
February 18, 2003, 00:37 |
Re: How to put human in a room?
If you use the icem-cfd,you can use the Autohex to finish it,it's very easy!
February 18, 2003, 03:16 |
what is icem-cfd?
I am using Fluent 5.3 |
February 19, 2003, 11:23 |
What exactly do you want a human in the room for??
Are you measuring heat transfere ?? it could be a WALL ...it depends on what you want to evaluate |
February 20, 2003, 01:03 |
I am trying to find an optimum supply temperature for a lecture hall in different situations.
Such as, optimum supply temperature when there are 100 occupants inside.... Right now, my solution is set the boundary conditions (for human) to wall, but I dont know what kinda "wall" should I set? Do I need to add Heat generation rate and other stuff??? Thanks in advance. ps. I am using Fluent 5.3 |
February 20, 2003, 05:05 |
Im no really fammiliar with Fluent 5., but a you can use the wall with the temperarute option and there you can specify the temperature óf the human and the heat generation rate.
February 20, 2003, 11:34 |
Hi you can use Kansas State University model for the human body heat transfer model. KSU have a very precise model for heat transfer study on human body. if you search in WWW you'll probably find some papers related to them. if you couldn't find something let me know to introduce you some useful paper. Regards Amir
[GAMBIT] Object in room with that object being the purpose of investigation | fluentgambituser | ANSYS Meshing & Geometry | 3 | August 24, 2011 02:52 |
average human body heat in a room | alessandro.zomparelli | FLUENT | 1 | August 5, 2011 05:43 |
Salome and Code Saturne simulation of simple room and objects | cristian.ocnarescu | Main CFD Forum | 0 | June 21, 2010 11:19 |
HVAC Modeling Humans in Room | LilBort | CFX | 27 | July 31, 2009 12:08 |
heat transfer: air in a room and water in a coil | Alberto | CFX | 2 | May 9, 2006 10:56 |
