Can Fluent 6.0.20 predict this problem right?
Old   March 5, 2003, 08:07
Default Can Fluent 6.0.20 predict this problem right?
Yazid Bindar
Dear All Fluent Users?
I would like to invite the Fluent Users to run the following 2D problem on FLUENT 6.0.20 (6's). After you get the result, you post it your comment in this user discussion group or you and me can discuss it personally. Here is the problem?
|--------------------------------| | f | d| | g |--------------------------------|--------------| b| | | |--------------------------------|--------------| a| | | |--------------------------------|--------------| c| | | |--------------------------------|--------------| e| | | | |--------------------------------|
Lengths of edges
a = 0.1 m (Inlet 1): Velocity Inlet
b = 0.15 m (Inlet 2): Velocity Inlet
c = 0.15 m (Inlet 3) : Velocity Inlet
f = 12 m (wall edges)
g = 3 m (wall edges) Boundry conditions
U (Inlet 1) = 17 m/s (normal to the edge)
U (Inlet 2) = 2 m/s (normal to the edge)
U (Inlet 3) = 2 m/s (normal to the edge)
Models: Flows only with Standard k & epsilon
I used turbulent kinetic energi intensity 6 % and hydrodimanic diameter (0.1 m, 0.15 m and 0.15 m)
I run it and I got the solution. I would like you to try it and we discuss the result. PLEASE DO IT with FLUENT 6. I did it with Fluent 6.0.20.
Good Luck
Yazid Bindar Chemical Engineering Dept., ITB, Bandung, Indonesia
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
Can Fluent predict stefant problem ? k FLUENT 0 July 26, 2006 05:26
