Tgrid meshing around cylinders in GAMBIT
Old   February 24, 2003, 12:11
Default Tgrid meshing around cylinders in GAMBIT
Chris
I've got square pipe with a filleted inlet in a large control volume. The "filleted" mouth is formed by the union of a semi-cylinder with the pipe wall.
I've split up the entire model into suitable chunks to mesh.
However, when I try to mesh the control volume (Tgrid), I always encounter problems, because of the filleted mouth...there's some skewness problem...
Has anyone successfully accomplished something similar before?
Old   February 25, 2003, 05:29
Default Re: Tgrid meshing around cylinders in GAMBIT
Erwin
You probable created a 'tangent' line at the location where you split the wall and the control volume. A tangent is where two lines gradually move closer to eachother creating extremely small long volumes. Try moving the split deeper into the pipe to make the fillet part of the larger volume. Or when that is not possible, don't make the fillet 90 degrees but make it e.g. 80 deg to eliminate the tangent line.
Old   March 5, 2003, 05:01
Chris
Thanks Erwin! My problem's solved!
Old   March 5, 2003, 07:43
Erwin
Most welcome!
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Hexa meshing two intersecting cylinders in gambit chat1983 ANSYS Meshing & Geometry 0 April 8, 2010 07:38
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing cylinders with boundary layer using Gambit Florence ANSYS Meshing & Geometry 5 April 1, 2009 12:36
using Tgrid meshing from gambit with FIdap philippe FLUENT 0 September 30, 2008 03:50
