Home > Forums > FLUENT
adiabatic walls yet enthalpy change
Old   February 24, 2003, 13:25
Default adiabatic walls yet enthalpy change
Chris
I've got flow through a pipe with a throat and adiabatic walls. The temperatures at inlet and outlet are equal, at 300K.
Presumably, under adiabatic conditions, with no work done on the flow within the pipe, I would not expect any change in the stagnation enthalpy of the fluid, right?
Yet, downstream of the throat, I get regions of higher stagnation temperature (~330K), which are then convected down the pipe.
Fluent reports that this is the converged solution, but I don't see how it makes sense!
Thanks in advance, if you are able to provide some valuable insight!
Chris
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 10 February 5, 2014 12:17
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Thermal phase change model Piti CFX 0 February 9, 2009 10:27
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
