Home > Forums > FLUENT
a problem
Old   March 2, 2003, 08:40
Default a problem
liu
When I use Fluent to compute 3D flow field, the following information appears: ˇ°Turbulent viscosity limited to viscosity ratio of 1.000000+05 in 18 cells.ˇ± What does it mean? Do I need to reset any parameters? Do it affect computation results? Thank you!
Old   March 3, 2003, 01:14
Default Re: a problem
zhhuang
1/check your model, shape and size,Maybe the size 2/check your fluid,the default is air,maybe your fuild is water or others
Old   March 3, 2003, 03:08
Raintung
I met with the same phenomenon. Can you explain in detail, please? What does the ˇ°sizeˇ± mean? The solver used is coupled and explicit. Thank you very much!
Old   March 3, 2003, 05:24
ff
Read in fluent user guide chepters about turbulence modeling and/or some books about turbulent modeling.
Regards, ff
Old   March 3, 2003, 08:15
zhhuang
Raintung,I mean maybe you create your model in Gambit,and the default length unit in Gambit is meter.while the real unit maybe is mm.But you forgot to scale the unit in Fluent,and the inlet mass is constant,the velocity will be dimiss.I hope I didn't confuse you! regards zhhuang
Old   March 3, 2003, 09:51
Raintung
Thank you! But,are there any other reasons? I don't know what should I do.
Old   March 5, 2003, 05:03
Marc Gugau
It means your turbulence model (I guess Standard k-e !?) calculates a turbulent viscosity that is higher than the maximum allowed value (solve/controls/limits). This often happens in stagnation points. You can check out the 18 cells by displaying 3d-contours of the interior-zone with a lower limit of 1e5. Furthermore you can avoid all this by choosing a more sophisticated turbulence model. Neverthless your computational result should only neglectably be affected.
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
