March 10, 2003, 06:49 |
Heat transfer through solid
In the FLUENT manual, it talks about modeling a heated surface between 2 zones, but I do not understand it completely. I am modeling air flow over a 2-D stream-lined body. There is a constant-temperature heating element (surface) on the bottom surface of the streamlined body. Obviously, there is conduction of heat away from the heating element on the lower surface by the air. I want to see how much heat is lost through conduction on the upper surface to the flow above the body. How can I do this, i.e. definition of boundary conditions? My heated element appears with a shadow zone. (?) Thanks in advance! |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
No Heat Transfer between two solid domains | Mike ZH | CFX | 7 | July 26, 2008 16:50 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
