pressure outlet B.C
Hi. all I want to konw how to set temperature gradient 0 in the flow direction at pressure outlet b.c.
Bacause I use idea-gas(density), so I can't use outflow. I have to write udf or Pressure outlet B.C is defaulted.. Anybody help me please!! |
Re: pressure outlet B.C
Hi
About the first question I don't have an idea About pressure outlet condition you don't need to write a UDF for the pressure outlet. However, if your pressure outlet is not constant you have to provide data or a profile to obtain an accurate solution of the flow field. Best regards Alex Munoz |
