The static temperature is higher than total temp
Old   March 27, 2003, 20:16
Default The static temperature is higher than total temp
devy
Now I simulate supersonic flow.I define the heat flux at wall is zero.
But I find the static temperature is higher than total temperature at wall.The total temperature is about 3000k.But the static temperature is higher 3500k.
Would you like to give me some advice?
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
Tf is averaged by static or total temperature ?? NPU_conanxie Main CFD Forum 0 April 6, 2011 21:30
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
Static and Total Temperature Tomislav FLUENT 4 December 4, 2006 04:59
What does the duct feel -Total or static temperatu John Main CFD Forum 1 August 7, 2002 05:15
