March 24, 2003, 05:13 |
Export mesh back to Gambit
Hello colleagues
Does anybody managed to export mesh back from Fluent to Gambit and save assigned boundaries definitions ? Thanks for replay Paul |
March 24, 2003, 16:13 |
Re: Export mesh back to Gambit
Open Gambit, assign solver (say Fluent 5), then import the mesh.
By doing it in that order you will maintain your BCs Pop |
March 28, 2003, 07:04 |
Thanks Pop
I did it in a just same way but all boundaries (INLETS, OUTLETS, PERIODIC, etc) are deleted after export *.case in Gambit. Does any GAmbit defualts influence it ? Does anybody meets this problem or only I am so lucky ? Paul |
March 30, 2003, 07:47 |
u are not alone, but i haven't tried much on it.. just observed that it does so (i mean what u said).
Export 2D mesh from ICEM to Fluent | BuilttoSpill | ANSYS Meshing & Geometry | 4 | August 28, 2010 08:16 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 02:19 |
export .db mesh from ansys to gambit | vajiheh | ANSYS Meshing & Geometry | 1 | June 2, 2009 22:09 |
export or convert gambit mesh to CGNS | zaidun | FLUENT | 6 | April 20, 2006 04:48 |
GAMBIT merge and export mesh | sean | FLUENT | 4 | March 8, 2001 07:50 |
