-   -   How to display Reynolds stresses (http://www.cfd-online.com/Forums/fluent/31167-how-display-reynolds-stresses.html)
ravi March 30, 2003 14:30
Hi, I am using a 2d model utilizing the k-epsilon RNG turbulence model, to simulate an open channel flow. How can i display the reynolds stresses at the node points. Under the display option there is none that i know of. Thanks for the help
regards Ravi
Padmabhushana r. Desam March 31, 2003 03:35
Re: How to display Reynolds stresses
Hi, Fluent does not have the Reynolds stresses option in the post-processing for k-epsilon family since it does not solve Reynolds stresses explicitly. The Reynolds stresses are modeled with Boussinesq approximation. If your problem demands accurate Reynolds stresses distribution, use the Reynolds stress turbulence model instead. If you are looking for a crude approximation, write a custom defined function using Boussinesq approximation, which relates the local mean velocity graidents to the Reynolds stresses through eddy viscosity.
Hope it helps
Good luck Bhushan
maphd April 14, 2014 12:53
Originally Posted by Padmabhushana r. Desam
;105140
Hope it helps
Good luck Bhushan
Hi, Padmabhushana
I need help about your above post? I am new to fluent, so if you could give me more detailed explanation, I really appreciate it. Could you explain to me how I can write custom defined function to calculate Reynolds stresses? I am using k-e model in turbulent flow.
