Flow Patterns
Old   April 1, 2003, 18:46
Default Flow Patterns
Andy
Hi Fluent Users,
I have modeled a 3D centrifuge which has an inlet and 2 outlets. When I started the flow simulation in Fluent, I assigned boundary conditions of Velocity Inlet and 2 Pressure outlets for the outlets. The Centrifuge has 2 walls, both rotating. Now when I look at the "Report Fluxes", I see that Fluent is predicting that theres only one outlet. In other words, Flow is coming in via inlet as well as one of the outlets. I also observed that when I am not rotating the 2 walls, then Fluent predicts that flow comes in, goes out through both the outlets. So when I rotate whats going on??? Any thoughts on this will be highly appreciated.
Thank you,
- Andy
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Instability and Vortex/roll structure Z. Zeng Main CFD Forum 3 May 10, 2000 05:18
