turbulent viscosity
Old   April 3, 2003, 13:07
Default turbulent viscosity
Dave Roper
I often get a problem with 'turbulent viscosity limited to viscosity ratio of 1.0 E+5' when using ke standard or ke RNG turbulence models. Have found ways of reducing it but don't really understand the fundamental reason why this occurs and what to do to eliminate it. Any one else know? Thanks.
Old   April 3, 2003, 19:57
Default Re: turbulent viscosity
Jongdae Kim
It's a serious problem. Especially, whenever I used second order and higher accuracy schemes, I usually had this problem. In that case, at first, I reduced the under-relaxation factor until 0.1 (in some special or extreme cases). Secondly, used first order scheme for turbulence viscosity term.
If this change is not working, please remesh your domain. There is no way.
Fundamentals or background? I have no idea.
Good luck.
Kim.
Old   April 3, 2003, 21:39
Alex Munoz
HI Dave
The turbulent viscosity ratio is telling you that there two adjancent cells with a high differences in velocity. Therefore, you should plot a contour of the turbulent viscosity ratio to identify the cells with the highest values. Then, adapt the mesh for these cells.
Best regards
Alex
Old   April 4, 2003, 03:36
lohen
Hi, it depends of the problem you are treated. plot the contours of k or epsilon, normally it corresponds to erroneous value of k and epsilon. to solve this problem, i declare the zone where there is such value as laminar zone at the beginning and uncheck it when the calculation is near convergence. It is especially efficient for euler-euler calculation with un a free surface (air-water for instance).
Bye
Old   April 4, 2003, 04:35
Dave Roper
Thanks everyone for responses.
Old   December 9, 2013, 07:43
annu is on a distinguished road
hi friends
i had similar problem regarding turbulent viscosity ratio, i had remeshed(refine the grid double the previous one) the grid, but viscosity ratio remains there.
please tell me how to sort out this issue.
your response will be highly appreciated.
annu is offline   Reply With Quote
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
