SCANF
Old   April 7, 2003, 18:26
Default SCANF
Alex Munoz
Hello CFD community
I wonder if someone knows a function similar to scanf, which could read string from the screen window. Unfortunately, it seems that Fluent does not support this C function in its UDF.
I really appreciate a suggestion of how to read strings from the window screen by a UDF.
Regards
Alex
Old   April 8, 2003, 11:28
Default Re: SCANF
Thierry
Hello Alex
Indeed it is not posible to use SCANF in FLUENT, you must use FSCANF instead ! (Fluent.Inc/fluent6.1/help/html/udf/node39.htm).
Maybe you can put your filename in a special file, which name is unvariant, and read this file with fscanf.
Thierry.
Old   April 8, 2003, 14:01
Default Re: SCANF
Vladimir Krejci
Hello both, function fscanf can read from standard input in C nad C++, I am not sure if it works in Fluent. The only difference is that you use 'stdin' instead of a your pointer to a file. The screen terminal (standard input and output) is treated as a file in this programming language. Hope it helps. Vladimir
Old   April 8, 2003, 15:44
Default Re: SCANF
Alex Munoz
Hello Thierry!
Thanks you for thinking a solution for my problem
Actually, I an using fscanf to read the file with invariant name. However, in my case I need to several data file, where the only difference between them is the name. Consequently I am looking for a C function which be able to read the name files from the MAIN FLUENT WINDOW
If you know a way to read these file without changing the name in the user define, compiling and running fluent over and over it will be great.
Best Regards
Alex Munoz
Old   April 9, 2003, 03:51
Default Re: SCANF
Thierry
Hello Alex !
I have well understood your problem...and I think it's not possible to access directly to the main fluent window. What I suggested you is reading a file with fscanf, which name is invariant (names.txt for instance), and that includes all the filenames you need.
Example :
names.txt contains : filename_1 filename_2 filename_3
and you use something like that !
char filename[20]; FILE *f; FILE *g;
if ((f=fopen("names.txt","r"))==NULL)
Internal_Error("NAMES.TXT NOT FOUND !!\n");
} else nb_files=3; for (i=0; i<nb_files; i++)
fscanf(f,"%s\n",filename);
g=fopen(filename,"r");
fclose(g)
fclose(f)
Of course you have to modify this file each time the filenames change, but you can avoid compiling the UDF.
Best regards
Thierry
Old   April 9, 2003, 14:33
Default Re: SCANF
Alex Munoz
Hi Thieery
Thanks you for your suggestion, unfortunately i can not do it, The files are extremely large and If I save the cas and data file plus several scalar files, I will run out of computer storage.
I guess I have to live with the problem!
Thank you
Alex
what is the format of.txt file for scanf to read lamlash FLUENT 0 July 17, 2006 18:04
