April 28, 2009, 23:42 |
how to implement blood properties on Fluent
baechtelguillaume
Rep Power: 17 |
Hi everybody,
I want to implement a new fluid on fluent. I need to put the viscosity (value=x), the surface tension (value=y) and the density (value=z) and maybe the viscosity law from blood. Is it possible to use the udf from FLuent ? Or do you think it is the same to use the materials panel which allows me to use non-newtonian fluid and to change the physical properties ? Thank you very much for answer, Guillaume |
April 29, 2009, 08:19 |
dhahbi
hi friend,
your problem is very easy so dont worry, you go to 'Define' and then chose 'Materials' a panel will open to caracterise your materials, so write 'blood' in name box then enter your own value of density and viscosity. if you want to use a non-newtonian fluid you should change the viscosity from 'constant' to 'non-newtonian-power-law' in the list then you enter the differents parametres (k,n,T0,minimum viscosity and maximum viscosity) finaly one click on the 'change/create' boutton be nice |
May 1, 2009, 00:16 |
baechtelguillaume
Rep Power: 17 |
It is working well, thanks a lot
May 15, 2014, 09:56 |
Pedro Saynovich
Rep Power: 11 |
February 13, 2015, 09:19 |
blood properties
Summer
Rep Power: 11 |
February 13, 2015, 09:38 |
Cees Haringa
I'd guess there should be quite a lot of papers published on the rheology of blood? A 2-second google-scholar search for example gives an often cited review by Merrill (1969) and I'm quite sure there's more modern literature available as well. So really, google (scholar) or some other literature database is your friend here. Which values you need? I'd think about what you want to know. If there is a wide range of literature values reported, it may be worthwhile comparing the different models (provided you can validate the flow profile or so). Perhaps the viscosity differs between people with regular blood, people who take certain medicine (EPO increases red cell count, so likely viscosity) and people with certain diseases (I would think sickle cell anemia would lower blood viscosity for example?), so that may also be a point of interest.
So asking which parameters you need is the wrong question. You should ask yourself which conditions you want to simulate, and search for the proper parameters in literature. Can't find it? Then find yourself a knife and a rheometer |
Display Modes | |
Chemical properties that are used in Fluent | kimej | FLUENT | 4 | August 19, 2011 11:29 |
DEfine NON NEWTONIAN Blood flow in FLUENT | jusepina | Main CFD Forum | 0 | January 18, 2009 16:43 |
FLUENT BLOOD FLOW RATE | Christoforos | FLUENT | 0 | September 18, 2008 10:08 |
Fluent Vs CFX, density and pressure | Omer | CFX | 9 | June 28, 2007 04:13 |
Earth as solid in Fluent, what properties ? | skwyky | FLUENT | 0 | July 2, 2004 10:04 |
