Home > Forums > FLUENT
x-velocity from text command
Old   April 21, 2003, 09:59
Default x-velocity from text command
Samir
Hi all, How can I specify velocity components (x-velocity, y-velocity ...) from a profile file in velocity-inlet BC, using text command.
Many Thanks
Old   April 21, 2003, 13:38
Default Re: x-velocity from text command
Alex Munoz
Hi
1) read case and data file 2) read profile
file>read-profile>
boundary-profile name[] "type your file name" 3) define the boundary conditions
define>boundary-conditions>velocity-inlet>
zone-idname [inlet]
velocity specification method:components[yes]
reference frame absolute [yes]
coordinate system cartesian X,Y,Z[yes]
Use profile for x-velocity [yes]
profile name []"type your file name"
data name [] "x-velocity"
Use profile for y-velocity [yes]
data name [] "y-velocity"
Use profile for z-velocity [yes]
data name [] "z-velocity"
Turbulent specification method K and Epsilon [yes]
Use profile for TKE [yes]
data name [] "turb-kinetic-energy" and soon
Hopefully you can follow my instruction
Best regards Alex Munoz
Old   April 22, 2003, 05:42
Samir
Thanks Alex,
Actually, I'm using a scheme file, so everything is ok down to (in your message)
profile name [] "type your file name"
I have used this command
(profile-name "myprofilename")
there was no error-message, but Fluent seems to ignore this instruction, so should I define a command to set velocity components?
Old   April 22, 2003, 12:43
Alex Munoz
Hi
Have you try to read your profile throught the GUI?
It seems to me that something it is not right!!!
The profile name is the filename located in the directory from where you are launching Fluent. It mush have all the caracters that you write, for instante, my file name is "pkehv" without any extension, if you write a name with extension you have to write "pkehv.tex"
Anyway do it first throught the GUI and check if it can read it!! Also under define>profile> you can delete, list and read profiles
Regards
Alex Munoz
Old   April 24, 2003, 13:20
Samir
it's Ok with a journal file, I first started with the GUI. Now, I'm trying to do the same thing every time step, but I don't know what's the procedure for achieving this work (UDF, Scheme file, ...). so, any suggestions are welcome
Regards
Samir
Old   April 25, 2003, 14:21
Alex Munoz
Hi
I have not working with scheme file. However, i suggest that you run this throught the bath mode or also calles background.
Best regards
Alex Munoz
Thread Tools
Trackbacks are On
Command to render text output from each mesh block pgopalak FLOW-3D 3 October 2, 2009 18:32
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
how to disable residual checkbox with text command zago FLUENT 1 July 15, 2004 21:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
