-   -   DPM and LES (http://www.cfd-online.com/Forums/fluent/31336-dpm-les.html)
R.Sripriya April 22, 2003 07:04
DPM and LES
We are working CFD modelling of hydrocyclones and are using LES for turbulence modelling. For simulating the particle trajectories we use DPM. When we use DPM with other turbulence models, in the "Display' "Particle Tracks" screen when we click "report type" as "summary" and the "report to" option as "file" then the "write" option automatically is displayed. This basically gives us the provision to write the results in a file and save it so that we can view it later. But this is not so in the case of LES with DPM . Even after the "report to file" option is clicked, the write option is not displayed. hence we are not able to write the results on to a file. also in the stochastic tracking model of DPM the number of tries option doesn't get on. Anyone of you have come across such problems. Please help R.sripriya
Alex Munoz April 24, 2003 01:56
Re: DPM and LES
Hi
the manual say DPM and LES are not compatible, I cannot tell you exactly the section number I guess 28. However, you can search at fluent userwebside fro compatibility and models
Sorry to give you bad news! I try to use the LES and DPM long time ago, Even I get in contact to Fluent support and they give the same answer "I can not run DPM with LES"
Regards
Alex Munoz
Alex Munoz April 24, 2003 02:17
Re: DPM and LES
Hi
Just I found the information on Fluent
Appendix A Fluent Model compatibility A1 Fluent Model compatibility chart
See by yourself
Regards
Alex Munoz
R.Sripriya May 13, 2003 22:48
Re: DPM and LES
Hi, Thanks a lot for the information R.Sripriya
