April 21, 2003, 12:50 |
Fluent-Ansys data transfer
I would like to transfer Fluent surface static pressure data to Ansys under windows platform. Does someone have any experience about this transfer?
Ahmet |
April 21, 2003, 13:48 |
Re: Fluent-Ansys data transfer
Hi
Go to write>profiles> then select your surface [inlet] then select your variable [static pressure] then click on write then select profile name [yourfilename] Regars Alex |
April 22, 2003, 02:14 |
Hi Alex,
Thanks for your massage. Is it possible for Ansys to read that profile. Generally, Ansys wants result file(rfl). |
April 22, 2003, 12:34 |
Hi
this file has a format Binary that is readable in whatever in whatever code. Even if you cannot read it, you can open the file and delete the head string that said something like "{y-velocity}" and then delete "{" at the begining and the end of the numbers. Regards Alex Munoz |
OpenFoam to Fluent data conversion Problem | vemps | OpenFOAM | 1 | August 8, 2011 02:30 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 14:04 |
Data import in Fluent?! | Bart Horsten | FLUENT | 3 | February 22, 2010 13:05 |
How to read tabulated data in Fluent | Siddhartha Pal | FLUENT | 0 | August 30, 2007 05:18 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
