-   -   particle velocity in DPM (http://www.cfd-online.com/Forums/fluent/31356-particle-velocity-dpm.html)
David April 27, 2003 09:07
Hi, everyone
Now I am simulating particle dispersed in air flow use DPM in FLEUNT 5.5. After converged, I want to display the particle velocity profile in different transverse position. But I cannot find the relevant command in GUI menu. Do I need use UDF to approach this target? If so, could you give me your experience or suggestion please?
Regards, David
Alex Munoz April 28, 2003 17:23
Re: particle velocity in DPM
Hi
Open report>discrete phase> sample>
select your
injection> surface> where you want your report of (x,y,z,u,v,etc) compute>
Fluent will write an output file in your directory, whic you can see by
open report>discrete phase>histogram
select read file>output plot histogram of velocity
Regards
Alex Munoz
David April 28, 2003 19:38
Hi, Alex
"injection> surface> where you want your report of (x,y,z,u,v,etc) compute>
Fluent will write an output file in your directory"??
where? I cann't find in my directory. which type file you mean? such like *.out or *.xy?
Thanks David
David April 28, 2003 19:46
Hi, Alex
After try, I got it. Thanks.
David
