May 6, 2003, 15:18 |
IF SOMEONE GOT THIS
Loading "C:\FLUENT.INC\fluent6.0\lib\fl_s112.dmp" Done. Could not check out fluent: Invalid returned data from license server Feature: fluent Hostname: Che_nt License path: c:\flexlm\license.dat; FLEXlm error: -12,122 For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
Hit return to exit. |
May 6, 2003, 21:34 |
Re: IF SOMEONE GOT THIS
Hi
I have not gotten this message before, but it seems similar to one that I got a couple months, which demand a check of the license agreement. Regards Alex |
May 7, 2003, 04:48 |
Looks like a license problem but I had a similar problem and it was a spy-ware program on my computer that was blocking the port used by Fluent.
Download a spyware program like ad-ware from http://www.lavasoft.de/support/download/ this might fix your problem. Hope this helps!! Mark. |
May 14, 2003, 06:45 |
Hello Zahid, I also got the similar message and it bugged me for quite a long time.At that time I was running fluent on Win prof. XP. Can you tell me which operating system you are using? This problem seems to be due to some network conflict with some other application on your machine. In my case this was due to the McAfee antivirus firewall feature. Please make sure that no other such software is blocking your connction with the fluent server.
Happy computing !!! Atul |
