Home > Forums > FLUENT
Grid generation for a tee junction
Old   May 8, 2003, 10:09
Default Grid generation for a tee junction
paal
anyone got a good strategy for meshing at tee junction of two pipes?
The two pipes I'm trying to mesh have very different diameters, on is 1.6mm in diameter and the other is 24.4mm in diameter.
The samler pipe is 1" long, the bigger 6" long, and the tee is located 2" from the end of the bigger pipe.
Due to the large difference in diameter volume meshing seems to fail, and trying to use boundary layers does not work either, gambit gives up and tells me that 3D BL only work for flat surfaces. I'm using GAMBIT 2.0.4
Any suggestions?
Cheers,
-Paal
Old   May 8, 2003, 11:35
Default Re: Grid generation for a tee junction
ap
You can try to mesh your T as follows:
- Create the two pipes, but don't unite them.
- Split the bigger pipe in three parts using a brick of rectangular cross section. The height of the brick should be at least equalt to the lenght of the bigger pipe. The side lenght of its face perpendicular to the smaller pipe should be between pipe diameters. The other lenght should be at least equal to the larger pipe diameter.
- Unite the central part of the biggest pipe, which you obtained from the splitting procedure, with the smallest pipe.
Now the decomposed domain can be meshed using Cooper tool.
Hi
ap
Old   May 8, 2003, 14:29
Alex Munoz
Hi Paal
You don't follow my advice read papers, it is not painful and you will stop bargain for help.
This time I am back in my office and I will give you exactly the name of the paper that already has done what you are thinking to do.
TURBULENT FLOW IN A 90 PIPE JUNCTION PART1 DECAY OF FLUCTUATIONS UPSTREAM THE FLOW BIFURCATION. Sierra Espinoca F.Z., Bates C.J, O'Doherty T. Computer and Fluids 29 (2000) 197-213.
You are lucky Paal, Sierra-Espinoza is a very well know for his CFD works. Therefore, you will enjoy this piece of work!
As this work there are many, as a result what you try to do it is not new!
Regards
Alex Munoz
Old   May 13, 2003, 07:25
paal
Thanks a lot! Just what I needed.
My mixing is just as expected showing nice horseshoe vortex formation downstream
Cheers,
-Paal
Thread Tools
Trackbacks are On
Grid generation of an airfoil in Ansys workbench 12.1 sunish5 ANSYS 1 October 26, 2010 23:29
need help for generation grid aya FLUENT 11 March 4, 2008 15:46
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 01:48
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 05:07
