May 28, 2003, 07:23 |
Total pressure and velocity inlet BC
I would like to set total pressure boundary condition at my inlet but in a way to define all components of total pressure (velocity magnitude, directions and static pressure). Is this possible in Fluent? Is it possible to set velocity inlet boundary conditions + static pressure at the inlet? Thanks in advice, ff |
May 28, 2003, 21:24 |
Re: Total pressure and velocity inlet BC
sure, it will be a problem because its not possible to make the both boundary condition ( pressure inlet and velocity inlet). May be u can separate them and use pressure inlet with total pressure value.
Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Total pressure and velocity inlet BC | ff | FLUENT | 1 | June 14, 2003 20:09 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
