How to export?
We know we can use the ˇ°In Planeˇ± in the ˇ°Vector Options Panelˇ± to visualize components that are normal to the flow. Then, we can use ˇ°hardcopyˇ± to output the vectorgraph. But it is difficult to modify the vectorgraph optionally. How can I export the graph to corresponding data to a ˇ°Tecplotˇ± file? Thank you.
Re: How to export?
fluent allows you export the data files into tecplot files. Click FILE/EXPORT and select Tecplot and what variables you want expot. If your tecplot is 9.0 version, it can load fluent case and data file directly.
Re: How to export?
Thank you! I believe you are right. But it is difficult to visualize components that are normal to the flow. By the way, how can I load fluent case and data file using tecplot 9.0 version?
Re: How to export?
in tecplot 9.0, click file/import/fluent data loader.
