May 11, 2003, 06:02 |
Time problem in parallel fluent
I am using parallel fluent and using a cluster of three PC's. When I made a comparison of time taken to execute same number of iterations for same problem, I was astonished to note that cluster of three PCs take more time as compared to a single PC. What is the problem? Thanks
May 13, 2003, 02:37 |
Re: Time problem in parallel fluent
There may not be a problem at all. If the case is only small then fluent spends more time communicating between processors than it does solving the equations. We have a four processor unit here and more often than not it is quicker to run the solution on two processors than on four. It is possible to increases the number of iterations between communications but we have found that this can lead to erroneous solutions at the joining of the partitions.
Stuart |
Parallel fluent problem | salvoblack | FLUENT | 2 | March 2, 2011 10:24 |
Parallel processing problem with Fluent | Harish | FLUENT | 3 | February 8, 2011 09:49 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
problem!! FLUENT 6.2 -SUSE parallel computing | khanjaved | FLUENT | 1 | August 15, 2005 22:00 |
parallel mode - small problem? | co2 | FLUENT | 2 | June 1, 2004 23:47 |
