????Compiling a udf with the "COMPILE" option ?
Old   May 17, 2003, 03:13
Default ????Compiling a udf with the "COMPILE" option ?
ROOZBEH
Hi all; I want to compile my udf with the compile option. My "libudf" directory is a subdirectory of "ntx86" directory. But during the compilation, I resived an error:
Opening library udflib... Error: open_udf_library: The system cannot find the path specified.
Error Object: ()
Please help me.
Old   May 17, 2003, 06:11
Default Re: ????Compiling a udf with the "COMPILE" option
george
The process I follow is: 1) open fluent 2) define>user-defind>functions>interpreted... 3) write the path of udf (c:\work\myudf.c) 4) OK 5) read case or mesh On my pc, it works well. good luck
george
Old   May 20, 2003, 05:43
mateus
Hi!
It looks like everybody has problems with compiled UDFs Maybe you can find something here:
http://www.cfd-online.com/Forum/fluent.cgi?read=12853
They had problems with dynamic mesh...
By the way, are you still working on Vof and cavitation? Any sucess?????
Best regards
MATEUS
Old   May 20, 2003, 05:52
Andrew Garrard
I have recently had problems changing the way I compile my UDF's. The procedure is quite different for different versions of fluent. Which version are you using, what platform is it on (I guess it is NT) and are you building the directory structure manually or through the fluent GUI?
I believe you my have not created a directory for your udf library, eg. libudf, in your working directory. The 6.1 manual does not tell you to do this although I believe it is necessary.
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
