May 19, 2003, 08:01 |
How to visualize the components
We know we can use the ¡°In Plane¡± in the ¡°Vector Options Panel¡± to visualize components that are normal to the flow. Then, we can use ¡°hardcopy¡± to output the vectorgraph. But it is difficult to modify the vectorgraph optionally. How can I export the graph to corresponding data to a ¡°Tecplot¡± file? Enough in tecplot9.0, it is not easy to to visualize components on the surface normal to the flow. What should I do? Thank you.
May 19, 2003, 23:17 |
Re: How to visualize the components
flie/export/tecplot
May 20, 2003, 03:43 |
Thank you, Shiping Liu, maybe you have gave me some good advice. But, I think you may misunderstand me, there is a good example in 25.1.3¡±Drawing Vectors in the Plane of the Surface¡±(fluent documentation), I only want to export the graph to Tecplot. Thanks a lot.
May 20, 2003, 10:47 |
when you get the tecplot file of the variables, you can use tecplot visualize the vectors.
Display Modes | |
how to extract the components of radial and tangential velocities from pump impeller | renyun0511 | OpenFOAM Running, Solving & CFD | 3 | October 31, 2022 10:31 |
how to extract the components of radial and tangential velocities | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | April 8, 2011 08:15 |
Transient Statistics for turbo components | Suzzn | CFX | 5 | May 4, 2010 10:56 |
reynolds stress components in CEL | Roberto | CFX | 0 | December 3, 2008 04:29 |
Flow directin components. | Nahari Ziv | FLUENT | 1 | March 28, 2005 21:12 |
