Home > Forums > FLUENT
GAMBIT-Wall with slip
Old   May 17, 2003, 23:15
Default GAMBIT-Wall with slip
Richard Toma
I am trying to model a pool with a free surface. The surface vertical motion will probably be negligible, so I need a wall with slip boundary. Any ideas which boundary in gambit gives this condition. I'm thinking symmetry, but Im not sure. Thanks so much
Old   May 19, 2003, 21:38
Default Re: GAMBIT-Wall with slip
Shiping Liu
Gambit can not directly set slip wall or moving wall. You just set this wall as a wall (better is give it a name),and then use fluent to set this moving wall.
Thread Tools
Trackbacks are On
Slip flow boundary condition on wall using UDFs mahdi haddad FLUENT 1 November 11, 2014 07:13
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Modelling free surfaces using no slip wall, and other general queries andy_mckay88 Main CFD Forum 1 November 18, 2010 06:54
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
velocity slip at wall SA FLUENT 0 March 30, 2003 20:32
