How to visualize the components
We know we can use the ˇ°In Planeˇ± in the ˇ°Vector Options Panelˇ± to visualize components that are normal to the flow. Then, we can use ˇ°hardcopyˇ± to output the vectorgraph. But it is difficult to modify the vectorgraph optionally. How can I export the graph to corresponding data to a ˇ°Tecplotˇ± file? Enough in tecplot9.0, it is not easy to to visualize components on the surface normal to the flow. What should I do? Thank you.
Re: How to visualize the components
flie/export/tecplot
Thank you, Shiping Liu, maybe you have gave me some good advice. But, I think you may misunderstand me, there is a good example in 25.1.3ˇ±Drawing Vectors in the Plane of the Surfaceˇ±(fluent documentation), I only want to export the graph to Tecplot. Thanks a lot.
when you get the tecplot file of the variables, you can use tecplot visualize the vectors.
