fuel cell simulation in Fluent
Hi everyone, I am trying to simulate the mole fraction of the species nearby the anode of a fuel cell. The boundary conditions include the anode as porous media and fuel gas inlet flow. The species will react on the anode. Can I build up such a model using the models provided in Fluent? Should I use UDF? Thank you all!
Re: fuel cell simulation in Fluent
I also am working on fuel cells. Depending on exactly what you want to solve depends on what tools you need to use. I found that I had to creat 3 UDFS.
Best piece of advice I can give you is to know what equtions you are trying to solve befor you begin to build a model. If those equations are avaliabe in fluent you may not need to use a UDF. The equations I have built a UDF for are the Butler Volmer equation and the current production. If you would like more information I may be able to help. |
Hello Andrew,
I work on modeling fuel cells as well. Could you give more details? e.g.Your model is two-phase or single phase? if two-phase flow, which model do you use? multiphase model or multispecies model or DPM? or something else? how do you model phase changes? Could you send me some UDFs for fuel cells? Thank you so much! rookie |
Separate User-group Fuel cell simulation
Guys,
I work in fuel cell modeling as well. I think we should form a usergroup or something about modeling of fuel cells to share information. I have been in this forum for quite some time and have considerable experience in CFD software. If interested in starting a separate user-group, I think we can all team together. Please let me know. Murali |
Re: Separate User-group Fuel cell simulation
I think it will be great if we can exchange ideas on this!
Hello Murali,
So far, found only a couple of guys working on Fuel cell in this forum. I think the simpliest method is to use email. In the mean time, I am going to develop an online fuel cell forum group, and posted on my website. But it may take a while for me to finish it. Thank you! Rookie |
rookie,
I have seen quite a few guys appearing in the forum with fuel cell interests. A user forum would be great too. I thought we could start something immediately so that we may not lose the people who are currently visiting. Once u start your forum, this yahoo group can be merged with yours. Does that sound ok to you ? Murali http://groups.yahoo.com/group/fuel_cells/ |
A have a question?
@Chino
Hey mate, What's your problem? Tell me I will do my best to answer it. Good luck |
Well, I don't know how I can apply the Bultler-Volmer equation, in some articles I have found some variables that I need.
The problem is with the local reactive concentration and the temperature in the microfluidic fuel cell, because I donīt know how this variable can be writing in the UDF Bultler-Volmer equation? The two variables are results of my simulation. The reactions in the anode a cathode has been achieved using "species transport" model, it is an isotermic reactions. It is difficult to explain, but I am very graveful with your help. |
Hi again.
1 Attachment(s)
@ Chino
Hi You should accept that you didn't ask your question exactly. It's quite vague and difficult to understand your mean. But, I suppose that you've probably have difficulty in recalling local temperature and concentration. Right? If so, you can recall them easily in the UDF by corresponding macro. For instance, you can recall temperature with C_T(c,t) or mass fractions of involved species by C_YI(c,t,i). That's my grasp of what you asked. Hope it helps Good luck |
I am also having a problem modelling the Butler-Volmer equation in an attempt to create an alternative model to the one provided by Ansys in fluent. I'm basically not getting the same results as the oficial model. I have set up a 2D fuel cell model and started by trying to solve the solid and membrane potentials as UDS equations with source terms in the catalyst layers based on the transfer current given by the overpotential (as the fluent manual tells you). I've set the value of the electric potential to 0.75 at the cathode terminal/wall and 0 at the anode and have zero flux BCs for all external walls. I've made the electron conductivity very low for the membrane and very high everywhere else and the reverse for the proton conductivity. I have 4 source terms, in the anode side I have Ra_plus for the positive electric potential and Ra_minus for the negative protonic potential which is the same magnitude but opposite sign. A similar situation occurs on the cathode side I have Rc_minus for the electric and Rc_plus for the protonic potentials. Like any good programmer I've copied most of the code from the pem.c udf provided with fluent but edited out the bits I don't need yet like the concentrations. A section of the listing for Ra_plus is below. The others follow the same pattern with signs changed accordingly and for the cathode side I subtract the open circuit voltage from the overpotential. /* UDF to calculate overpotential using two electric potential fields defined as uds and transfer current source */ #include "udf.h" #define TINY 1.0e-16 #define Farad 9.65e7 #define alpha_c 0.512 #define alpha_a 0.5 #define i_ref_a 100000 #define i_ref_c 100 #define v_oc 1.01 DEFINE_SOURCE(Ra_plus, c, t, dS, eqn) { /* Assign the UDS index numbers */ enum /* user-defined scalar (UDS) */ { phi_s, /* solid phase potential */ phi_m, /* membrane phase potential */ n_uds_required }; enum /* user-defined memory (UDM) */ { surf_eta, /* 6 overpotential */ trans_current, /*13 transfer current A/m3 */ n_udm_required }; /* Set overpotential as difference in two potential fields */ real source=0.0; real c_c = 0.2; real c_w = MAX(c_c,TINY); real eta = C_UDSI(c,t,phi_s)-C_UDSI(c,t,phi_m); real A_p=0.0; real sat = 0.0; real s_corr = 1.0; real gamma = 1.0; int i=0; int n_electrons=2; real alpha_eta_a, alpha_eta_c, exp_a, exp_c; const real exponent_limit = 25.; const real exp_big = exp(exponent_limit); const real exp_sml = 0.; const real eta_cut = 1.0e-10; /* prevent over- and underflow of exp() */ alpha_eta_c = alpha_c*eta; if (exponent_limit < alpha_eta_c) exp_c = exp_big; else if (-exponent_limit > alpha_eta_c) exp_c = exp_sml; else exp_c = exp(alpha_eta_c); /* prevent over- and underflow of exp() */ alpha_eta_a = alpha_a*eta; if (exponent_limit < alpha_eta_a) exp_a = exp_big; else if (-exponent_limit > alpha_eta_a) exp_a = exp_sml; else exp_a = exp(alpha_eta_a); A_p = i_ref_a*(exp_a-exp_c)/(Farad*n_electrons); C_UDMI(c,t,surf_eta) = eta; dS[eqn]=(alpha_a*exp(alpha_eta_a)-alpha_c*exp(alpha_eta_c))*i_ref_a*pow(c_w,gamma)*s _corr; /*anode*/ //dS[eqn]=(alpha_c*exp(alpha_eta_c)-alpha_a*exp(alpha_eta_c))*i_ref_c*pow(c_w,gamma)*s _corr; /*cathode*/ source=A_p*n_electrons*Farad*pow(c_w,gamma)*s_corr ; return source; } If anyone is willing to help I can send them images and the case and udf files Kind regards Tom |
Thank you
@ Chino
why not. I will see like others and do my best to help you. Share it on this page whenever you complete it. Good luck |
1 Attachment(s)
I'm modeling DMFC, and i need to write a udf, but i don't know how to define Butler-Volmer equation. I saw overpotential defined by UDS in many paper, Is current density defined in UDS source macro or in adjust macro? please help me! |
you need to use user defined scalar (UDS) to calculate Butler-Volmer equation.
adjust macro is just a macro to be executed before each iteration/time step read ansys fluent customization manual for more information |
