May 22, 2003, 05:02 |
continuity residual oscilation
Hello
I have a problem of convergence: the residual curve of the continuity equation remains oscillating around 0.001 without stabilizing. I'M using the Diphasique VOF model , I changed several parameters (discretization scheme, decreasing the time step and the factors of under relaxation ) in accordance with the instructions in Fluent Documentation but the problem persists... Knowing that all the other equations (of movement and turbulence) converge very well (until 0.0000001) except that of continuity Does any one have any idea to improve this convergence. Otherwise, is convergence criterion of 0002 or 0.003 is enough in such case (VOF, diphasique , jet modelisation). Thank you in advance Mohamed |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
