mesh of large aspect ratio region
Old   May 24, 2003, 23:18
Default mesh of large aspect ratio region
marangoni
Hi:
In gambit, I try to mesh a face(rectangle): the length is about several meters, but the width only about 200 micron. After I mesh the face(the aspect ratio is about 1:10000), what I find out is for the region some distance from either end of long side, the mesh is not the same as that at either end. When I read grid into fluent, the minimum and maximum volume shown are not the same (the difference is quite large), some time even fails the grid check (negative area and volume). Anyone has some suggestion about this?
Thanks
M
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Mesh aspect ratio aka OpenFOAM 0 August 21, 2011 02:43
Ratio between bl mesh and volume mesh nazario ANSYS Meshing & Geometry 0 July 7, 2009 06:33
