continuity residual oscilation
Old   May 22, 2003, 06:02
Default continuity residual oscilation
Mohamed
Hello
I have a problem of convergence: the residual curve of the continuity equation remains oscillating around 0.001 without stabilizing.
I'M using the Diphasique VOF model , I changed several parameters (discretization scheme, decreasing the time step and the factors of under relaxation ) in accordance with the instructions in Fluent Documentation but the problem persists...
Knowing that all the other equations (of movement and turbulence) converge very well (until 0.0000001) except that of continuity
Does any one have any idea to improve this convergence.
Otherwise, is convergence criterion of 0002 or 0.003 is enough in such case (VOF, diphasique , jet modelisation).
Thank you in advance
Mohamed
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
