Home > Forums > FLUENT
iterations in transient flows
Old   May 22, 2003, 09:16
Default iterations in transient flows
ben
Hi Fluent users,
I am doing a transient flow calculations and would like to set the minimum number of iterations, but don't know how to do this. Does someone know how to do this? Thank you!
Old   May 22, 2003, 09:35
Default Re: iterations in transient flows
prasanth
no of iterations will be depended oon the time upto which the problem has to be analysed..i.e. if u decide the time step size..then the no. of time steps will be obtained by dividing the total time by the time step size. now. no of iterations per time step has be arbitrarily as high as possible..such that within that..it will converge in each time step... ok. all the best prasanth
Old   May 22, 2003, 14:51
ben
Thanks Prasanth for your response. Sometimes Fluent does very few iterations and declare convergence. I was wondering if there is a way to fix the minimum number of iterations without changing the residual. I'd like Fluent to do a minimum of 8 iterations even if it thinks that it converged!
Old   May 23, 2003, 01:05
Philipp Beierer
I guess one way to enforce x iteration steps is to reduce some of the limits in the convergence criteria list.
Hope this helps!
Old   May 25, 2003, 16:06
Default REducing the Empirism in Unsteady cases
Alex Munoz
Hi Ben
I apologize for do not answer you before, but I have been disappointed with the quality of the forum recently.
To determine the time step you have to estimate the Strouhal number of your case. Search for a case study under the name unsteady laminar flow behind a circular cylinder posted on fluent documentation (validation 6.0).
Just to give you one idea
Strouhal=(Obstacle diameter)/(period*velocity)
Then you should get your experimental strouhal number for your case and then estimate the period that you need.
The number of iteration per time step should be at least 20 iterations per time step. if you case request more number of iteration step reduce the time steps.
The number of time steps should be determine as follow:
Locate a dot in the point that you are expecting fluctuation of one of the velocity components.
then, register the above information at every time step using the surface monitor ( see surface monitor instructions)
Finally, when the history of this velocity points is stable (same wave amplitude and frequency) you will know that you have obtain the right solution for a periodic flow.
Best regards
Alex Munoz
Thread Tools
Trackbacks are On
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
