evaporation from liquid surface to ullage?
Old   May 22, 2003, 08:23
Default evaporation from liquid surface to ullage?
prasanth
hi I am user of fluent for 2 years. The present problem is as follows: a closed cylindrical tank in which liquid hydrogen is partially filled(cryogenic propellant tank). Now, since the liquid will be stored at 20k,there will be heat leakage into the tank. so there has to be evaporation from liquid to the ullage space... I am solving this problem in fluent using VOF model and there is no option for evaporation..so presently i am trying using UDF for mass transfer at phase interaction panel. I am struggling to come out with a perfect equation including vapor pressure. So can you help me in this regard. thanks in advance prasanth
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Modeling evaporation along free surface (VOF) sandeshsd ANSYS 1 February 17, 2010 06:24
Shear stress on liquid surface akr FLUENT 3 June 15, 2007 01:18
Liquid fueled Droplet Evaporation Ray FLUENT 8 January 3, 2007 00:36
evaporation from liquid surface to ullage? prasanth FLUENT 0 May 22, 2003 08:22
