Can that be possible?
Old   May 22, 2003, 05:41
Default Can that be possible?
majestywzh
I have used fluent for several month , but finally I found fluent is of no help as it comes to my project,i.e water-solid particle flowing at the tube(the solid particle melt and absorb heat,enhancing the heat transfer).the solidification/melting model built into fluent, however, just doesn't fit such a particle melting case.
Dear friend,do you have any suggestion?
Now i am thinking about writing code by myself,and accounting for the phase change.can i use some methods and call for the Fluent solver in my c-language code?Does fluent provide such an API for user?
Possible? thanks every body.
Old   May 23, 2003, 02:44
Default Re: Can that be possible?
Alex Munoz
Hi my magestic friend
I think you should breath deeply and think twice.
If you want to write your own code, you have to request to Fluent support some of the variable macros that are not available, which could take months. In addition, I know that some people have write their own code and after several months there code just provides 5% better results that the default model in Fluent. Moreover, some people expend tremendous amoung of time try to make their model converge.
In conclusion, practice your YOGA before making a decision to write your own code. I my opinion just finish your project with what you have and move on to another one.
Best Regards
Your trully friend
Alex Munoz
Old   May 25, 2003, 12:38
Colin
Agree with Alex
Old   May 26, 2003, 03:55
zxaar
I also fully agree with above comments, I feel YOGA is better option.
Old   May 27, 2003, 03:28
phd_y2k2001@yahoo.com
I think Alex is a Fluent agent where did you find 5% data, alex ? Could you show me a single reference?
Old   May 28, 2003, 01:41
Alex Munoz
Hi phd_y2k....
I wish to be a fluent agent! I have working a lot with fluent during the last year, and also I have many friends that have tried to improve the hydrodynamic model with no significant improvements.
Best regards
Alex Munoz
