Symmetry
Old   May 30, 2003, 03:43
Default Symmetry
Tobi
Hi everybody!
Please can you give me a answer to my question:
I have a 3D-Volume with a velocity inlet (calculated by given massflow)
Now I split the volume and use only a quarter to do calculations. I also use symmetry-BC
Are the calculations done for the hole volume or only for a quarter?
With best regards
Tobi
Old   May 30, 2003, 08:13
Default Re: Symmetry
mateus
Hi!
If you use the simmetry bc it means that conditions are expected to be the same on the other side of bc (in stedy case). So calculations can be made only for that quater of volume - this speeds up he calculation. The flow parameters (velocity, pressure field...) in the other 3/4 of the volume are simmetric to the calculated ones.
regards
MATEUS
Old   May 30, 2003, 09:37
Karl
What about non-steady case?
Old   May 30, 2003, 10:00
ap
The calculation is done only on 1/4 of the volume.
Old   May 30, 2003, 10:08
ap
If the flow you're modeling has unsteady characteristics, like gas flow in a liquid-gas column or granular solid flow in a gas-solid flow, you shouldn't use symmetry condition.
You can apply symmetry condition for example to a flow of water in a straight pipe, even if you do an unsteady calculation, because you expect the flow behaviour to be symmetrical.
If you impose a symmetry condition to a flow with unsteady behaviour you risk to obtain non-physical results.
Old   May 30, 2003, 10:56
Karl
But it is correct to use symmetry to model a free-slip wall or free surface (that does not change shape)even in highly transient flows?
I want to use symmetry to model a wall that has free-slip. In this way I want to get rid of a large portion of domain that is far from the region of interest, and I believe the flow beyond the placement of the symmetry condition has little effect on the remainder of flow, even though the flow is highly time dependent everywhere. (The velocity normal to the placement of the free-slip wall is approximately 0, even in the true flow situation)
Old   May 30, 2003, 16:14
ap
I think you can use symmetry.
If I'm not wrong, your flow is transient but also symmetrical, so if you use symmetry, you don't impose an unreal condition.
Hi
ap
Old   May 30, 2003, 17:17
Alex Munoz
Hi
From experiments, I have ever seen any periodical flow that presents symetry. I guess you could made this asumption. However, you should be aware of the reality!
Regards
Alex Munoz
Old   June 4, 2003, 09:43
zalhit
maybe symmetry show 1/2, but not show pipe or cube
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Forces in Symmetry Matt CFX 2 February 25, 2009 05:41
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
radiation and symmetry Mark FLUENT 2 November 4, 2004 13:50
