May 14, 2003, 13:14 |
molar concentration marco
In the multispecies model, we can retrieve species mass fraction using C_YI(c, t, i). Does anyone know what is the marco to retrieve specie molar concentration something like C_YI? Thank you! |
May 15, 2003, 09:23 |
Re: molar concentration marco
May 15, 2003, 09:29 |
I don't know if you can get the UDF to pull out the molar concentration or not. I believe that fluent calculates the mass fraction during the iterative process and then converts this to a molar concentration when requested, for example in a contour plot. You can get your UDF to produce a molar concentration by multiplying the mass fraction by the density and dividing by the molecular weight something like
mol_conc = yi[0] * C_R(c, t) / mw[0]; I don't know if that will you will have to play around with it, but that is how I intend to produce the molar concentration. |
June 12, 2003, 21:51 |
Hello Andrew,
Your idea works! Thank you a lot. Rookie |
Display Modes | |
dpm concentration | HK | FLUENT | 0 | March 6, 2008 06:44 |
Concentration Scale Data Interpretation | usker | Siemens | 4 | October 23, 2007 21:30 |
negative species concentration again | Andrew Garrard | FLUENT | 0 | March 22, 2005 12:36 |
initial concentration in multicomponent mixtures | isidro | Siemens | 0 | April 26, 2004 08:40 |
implement the molar concentration eqs? | YW | Siemens | 0 | October 1, 2003 15:56 |
