UDF Boundary Condition
Old   June 4, 2003, 12:38
Default UDF Boundary Condition
Dennis
When using a UDF to implement a BC does the profile have to be a continuous function or can you insert specific points on the boundary and have Fluent fill in the gaps.
Thanks for your help
Old   June 4, 2003, 13:27
Default Re: UDF Boundary Condition
Murali
I do nto think u can think of FLuent filling the gap. You have two options:
(1) define a profile (2) read data from a file for the mesh points
I donot think any other method works.
Murali
Old   June 4, 2003, 17:53
ap
You can interpolate your data and implement the equation you obtained in a UDF.
Hi
ap
Old   June 4, 2003, 22:41
DENG
Maybe you do not explain your problem cleasly. if you want to define a function along the boundary, it is simple. if you want to define an incontinuous boundary condition on the two sides of the boundary, it can be implemented by UDF.
Old   June 6, 2003, 16:17
Dennis
Thanks for your help. What I have is a 2-D boundary plane on which I will know velocities at cerain points in a grid taken from experimental data. From what you've said I will use a math program to create a function from the velocities and then use a UDF to implement it, unless someone knows of a better way.
Old   June 7, 2003, 10:09
mahesh
you can give your data points through piecewise linear function.. But I dont know how actually works.. c the fluent manual for B.C.
Mahesh
Resolved: Changing boundary condition with UDF according to pressure outlet boundary alpemre Fluent UDF and Scheme Programming 12 February 24, 2014 10:18
UDF for inhomogenous Neumann boundary condition akhilesh Fluent UDF and Scheme Programming 3 December 24, 2012 11:14
Boundary Condition Types Using Scheme and UDF Nasir FLUENT 0 September 15, 2008 21:54
UDF for the boundary condition Sridhar FLUENT 3 July 13, 2001 19:18
UDF : boundary condition ID Flav FLUENT 4 June 28, 2001 09:52
