Paraboloid Velocity profile
Old   June 4, 2003, 13:48
Default Paraboloid Velocity profile
Ronak Shah
Hi, I have to put a velocity profile (fully developed) at the inlet of a 3D case. The profile is like a paraboloid centered at middle of the pipe I know that there is an example in the UDF chapter on FLuent doc but there's no 3D case example (definition of a parabolic profile at inlet):
----------------------------- #include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, position) = 20. - y*y/(.0745*.0745)*20.;
} end_f_loop(f, thread) } ----------------------------
I don't know how to change that in 3D with the center of the inlet NOT being at the orgin. ( i know there is a thread about this but my case has a slight difference that the inlet pipe is not centered at the orgin. . Someone could help me?
Ronak Shah
Old   June 4, 2003, 17:51
Default Re: Paraboloid Velocity profile
ap
You can do two things:
1. Translate/rotate your domain so that the center of your inlet is the origin of axis system and the z axis has its positive direction going inside your inlet. This way you can use the paraboloid I wrote in the thread you make reference to. This should be the easiest way, but you have to pay attention when you specify gravity components, because if you translate/rotate the domain, gravity might not be aligned with one axis.
2. Look for a Math book about rotations and translations, find equations for these transformations and apply the right translation/rotation to the equation of the paraboloid. Then you have to change the UDF code to use the equation you obtained.
Hi
ap
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
