Convert existing Star-CD simulation to FLUENT
Old   June 9, 2003, 15:21
Default Convert existing Star-CD simulation to FLUENT
Lam
Hi. I am a CFD beginner who will model turbulent flow using FLUENT from existing Star-CD model. Can I convert the Star-CD model directly and run the simulation in FLUENT package? Is there any functions or methods to do that? Or it is something not related completely between these two package? If you have any information or idea, please let me know. I appreciate your opinions. Thanks.
Old   June 10, 2003, 04:51
Default Re: Convert existing Star-CD simulation to FLUENT
ff
Look in manula for CGNS
ff
Old   June 10, 2003, 12:26
Lam
Thanks for your opinion. I found that Star-CD can write cgns file and FLUENT can read cgns file.
Is there any built-in export and import functions which I can use in Star-CD and FLUENT or I have to code the cgns file by myself?
Old   June 10, 2003, 13:00
Vladimir Krejci
Try to have a look in manual or go through some menus within any of these codes. like for Fluent menu: file/export or file/import it is a bit more complicated within STAR-CD but if you type command: convert followed with help you will see all commands you need (to get help for particular command type 'help command')
or go to tools/convert/foreign (or something like this) or using STAR-guide folder: export or impoert grid(results)
Hope it helps.
IC engine simulation tutorial by FLUENT yash FLUENT 4 April 6, 2015 20:44
CFD-analysis of hydroplane: STAR CCM or Flow Simulation? peterg07 Main CFD Forum 0 February 7, 2010 15:32
Fluent simulation over airships Aragon FLUENT 8 March 30, 2009 13:12
Fluent simulation over airships Aragon FLUENT 0 March 27, 2009 13:38
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
