June 15, 2003, 17:36 |
Display Error
I'm running Fluent 6.1 on an XP machine, and I keep getting an error message whenever I try to display anything. Error: Floating point error: divide by zero Error Object: ( ) The display window then opens up, however it is blank. Does anyone know how to fix this? Thanks, Pat |
June 16, 2003, 07:12 |
Re: Display Error
i had one time a graphic problem but it was related to the graphic card when i remember correctly. i could fix it by starting FLUENT with the following command:
C:\Programme\FLUENT.INC\ntbin\ntx86\fluent.exe -driver msw (which sets the microsoft display driver as far as i understood) maybe it helps... Stefan |
June 16, 2003, 10:30 |
Re: Display Error
Stefan,
That was the problem, I needed to specify the driver. Thanks for the help!! -Pat |
nonNewtonian viscosity model | mhassani | OpenFOAM Programming & Development | 5 | January 7, 2013 09:27 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
