Home > Forums > FLUENT
3D Bend Creation
Old   June 16, 2003, 06:21
Default 3D Bend Creation
Konda Reddy
Hi !!! i am new to Gambit as well as fluent. i want to create a U-tube. In what way i can create . can anyone suggest me the method that i have to follow. thanks in advance..
Old   June 16, 2003, 16:29
Default Re: 3D Bend Creation
I think you can create the U by sweeping a circular surface and then adding the two straight pipes, as follows:
1) Create a circumference having the same radius of the pipe, having its center in the origin of axis.
2) Create an arc of 180° uniting the centers of the two cylinders. You can create the center of the second cylinder by making a vertex.
3) Sweep the circumference along the arc.
4) Create the first pipe using the cylinder tool.
5) Copy it translating it on the free base of the U.
8) Unite the three blocks you have.
Maybe it's not the best solution, but it should work.
Old   April 21, 2010, 10:45
sri99iitm is on a distinguished road
dude but sweep along the arc z not possible .. i tried
can u tell any better way to draw 3D U - tube
sri99iitm is offline   Reply With Quote
Old   April 22, 2010, 01:08
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
create the path (U) with curves
Then merge all the curves for getting one edge.
Create your surface section, and place the edge at the center of your section.
Finally sweep face with this edge.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Particle profile in a bend (gas-solid flow) Angeline FLUENT 0 June 27, 2011 03:15
How to draw velocity contours along the bend of U-pipe mariam.sara FLUENT 1 March 20, 2011 09:12
how are boundary conditions in bend with 2phases flow? s_baghalian CFX 14 October 7, 2010 17:05
Bend pressure drop ankita FLUENT 0 August 21, 2009 09:19
180 degrees bend flow Tim Franke Main CFD Forum 0 February 1, 2000 08:28
