multi-component flow-new species?
Old   June 16, 2003, 12:44
Default multi-component flow-new species?
Shankar
Hello all,
I am doing a multi-component flow with 2 gases.I have to study the effect of a particular property(say viscosity) of one of the the gases on the fluid flow.
So I changed the value of this property and did the simulation. But I get an error message :
'cell_function_values : unrecognised function : species ...'
How do I change the properties of a species or how do I create a new species that would be recognised by Fluent.
Thanks, Shankar.
Old   June 16, 2003, 15:11
Default Re: multi-component flow-new species?
emre
I get no error message when I define a new material, change-create it, then select mixture from material type and edit the mixture species names (just adding or substracting so that species traveling thru the other is the first name in the names list)even after simulation. You may follow these steps if you have not already done so.
Best Regards emre
Old   June 16, 2003, 18:29
Shankar
Yes, I have done that already.
Thanks for your response.
Is your simulation working when you change any of the properties of the component fluids?
Old   June 17, 2003, 13:33
cg
Sounds to me like you have a monitor defined for a species mass fraction (say species-3) which has been disabled. Can you turn off monitors?
Old   June 18, 2003, 16:55
Shankar
Oh thanks !
That was the problem.
Thanks again, Shankar.
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 12:12
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
HELP: User subroutines for multi species system sherry Siemens 0 October 8, 2004 11:08
Constrained Species in Multicomponent flow Jonathan CFX 10 October 22, 2003 21:44
component flow direction fieldnames for boundary profiles required. Ricky Wong FLUENT 1 May 12, 2000 10:36
