Loop over particles
Like Tree1Likes
  • 1 Post By Alex Munoz
Old   June 24, 2003, 10:50
Default Loop over particles
Umesh Shah
Does anybody know how to get loop over all the particles entering a cell. The particles are tracked using Discrete phase model in Fluent6.0.
Thank you all for your time.
Umesh
Old   June 24, 2003, 17:56
Default Re: Loop over particles
Alex Munoz
hi
I gave you this macro before for your concentration problem. I coopy this UDf from fluent
Example UDF that demonstrates DEFINE_DPM_SPRAY_COLLIDE ************************************************** **********/ #include "udf.h" #include "dpm.h" #include "surf.h"
DEFINE_DPM_SPRAY_COLLIDE(udf_man_spray_collide, tp, p) { /* non-physical collision UDF that relaxes the particle */ /* velocity and diameter in a cell to the mean over the */ /* specified time scale t_relax */
const real t_relax = 0.001; /* seconds */
/* get the cell and Thread that the particle is currently in */ cell_t c = RP_CELL(&(tp->cCell)); Thread *t = RP_THREAD(&(tp->cCell));
/* Particle index for looping over all particles in the cell */ Particle *pi;
/* loop over all particles in the cell to find their mass */ /* weighted mean velocity and diameter */ int i; real u_mean[3]={0.}, mass_mean=0.; real d_orig = tp->state.diam; real decay = 1. - exp(-t_relax);
begin_particle_cell_loop(pi,c,t) {
mass_mean += pi->state.mass;
for(i=0;i<3;i++)
u_mean[i] += pi->state.V[i]*pi->state.mass;
} end_particle_cell_loop(pi,c,t)
Best regards
Alex Munoz
wc34071209 likes this.
Old   June 24, 2003, 18:17
Umesh Shah
Hello Alex,
Thanx for your time. But I guess this looping macro is available in Fluent 6.1 since this is an example in it's manual.
I am using Fluent6.0. Do u know if i can use
begin_particle_cell_loop(pi,c,t) for my case?
Because there is nothing about this macro anywhere in fluent6.0 UDF manual.
Thanks again for your help.
Umesh
DPM: UDF - loop over all particles chris Fluent UDF and Scheme Programming 31 June 17, 2020 05:52
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
