Home > Forums > FLUENT
convection-diffusion equation
Old   June 25, 2003, 05:44
Default convection-diffusion equation
Hamid
has anybody solved non-linear convection-diffusion (convection dominated case) equations using Fluent? We have a non-standard problem and would like to slove it using UDFs, has anybody attempted this before? There is little difficulty in setting up the equations but boundary conditions for UDF based equations seem to conflict with standard |Fluent terms, can you help with this?
Old   June 26, 2003, 21:04
Default Re: convection-diffusion equation
Greg Perkins
I've solved these type of problems using USER DEFINED SCALARS (UDS). My experience has been mainly using UDS to model scalars without convection - actually I model solid phases that are generally stationary.
I have modelled them with convection using a user routine for the convective flux, but I found coding this very tricky. While I have got it to work, I still don't completely understand what FLUENT is doing. I think part of my difficulty was I used my own convective flux and continuity for the second phase.
If you are talking about modelling scalar transport which is convected with the existing flow field, then I think it will be much easier, since you wont have to code the convective fluxes.
While Fluent provides standard bc for the scalars, its possible to completely override these by applying your own flux formulation at the boundary. So you can do whatever you want - it just takes a quite a while to work it out, though the documentation has improved a lot with Fluent 6.
Greg
Old   June 28, 2003, 00:50
rr
about this problem, I do not know your boundary condition. However, I think you can modify the standard boundary condition offered by Fluent. I have succeeded in doing it by UDF.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Estimate convection and diffusion terms in transport equation Lance CFX 0 April 4, 2011 11:16
recommended book to the study of reaction diffusion convection equation? lfgmarc Main CFD Forum 1 January 14, 2011 07:34
convection diffusion equation in 2d ali2108 ANSYS 0 May 24, 2009 13:56
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 08:14
