Home > Forums > FLUENT
Using Fluent with VNC
Old   June 26, 2003, 17:39
Default Using Fluent with VNC
ugur
I just installed vncserver on a RH 8.0 workstation. Whenever I try to use fluent with vnc, the menu text characters doesn't display correctly> Is there anybody knows why this happens and how to fix it?
Thanks...
Ugur
Old   June 28, 2003, 15:40
Default Re: Using Fluent with VNC
jx
Ugur,
I did this way also, if you mean you run Fluent on the machine where venserver is running on and connect it from another machine with vncviewer. I even run Fluent on x0rfbserver. Both way I have no problem.
Both vncserver and x0rfbserver do all actual work on the server machine. While vncviewer just makes a exact copy of the screen.
Therefore, I believe your problem lies on the server. More specifically, it might be a font problem. If you have physical access to the server machine, you can try run it there directly, to see if the problem comes up or not. If you can not, you can run Fluent over ssh with X-forwaring. The difference is that this way the font rendering is done on your client machine. You have to run X server on your client amchine though. For *nix, you already have X installed, for windows, you can choose Exceed (coming with gambit, so in Fluent CDs), X-win32, Cygwin+XF86 (GPLed software, so free), or others.
Hope this helps.
Old   June 28, 2003, 15:52
jx
Sorry, precisely speaking, XFree86 is opensourced but not GPLed. But anyway, XF86 on cygwin provides you a free Xserver for windows. Also ssh is in the cygwin package.
Since you run Fluent on vncserver, this offer your another choice free from commercial software.
HTH
Old   June 28, 2003, 17:01
ugur
Thanks for the repsonse. I do have physical access to the linux box, and when I run Fluent on the Xwindow of RH 8.0, I don't have any problem. So if this is a font problem, probably the xserver vnc is running doesn't recognize the font. Other than fluent menus, everything is fine. Is there anyway to modify fluent fonts to use a more standard font? ugur
Old   June 28, 2003, 19:25
jx
That's odd then.
Maybe you should check the vncserver script to make it use same font path as X. I just remember vncserver is a script to invoke Xvnc, not sure if it sets up different fonts from the main X server.
I don't think fluent use wield fonts for its menu.
My suggestions are:
1. can you vncviewer to localhost to make sure the error happens on the server. 2. When on remote client machine, you can use ssh with X-forwarding and run X server on it. 3. use x0rfbserver. It works like WinVNCserver with windows. Since you can run fluent without problem on the server, you still use vncviewer to connect the server.
HTH
Old   July 2, 2003, 13:26
jx
Uger,
I just had the same problem when I tried to run fluent remotely on a server which I don't have physical access to.
I tracked down the vncserver (a perl script) and found there *is* font path settings in it. I just uncommented them and changed to
$cmd .= " -fp unix/:7100";
Then everything works.
Hope this helps.
Old   July 18, 2003, 13:14
ugur
Thanks jx;
I tried it and it works.
Thread Tools
Trackbacks are On
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
