How to modify velocity with UDF
Old   June 28, 2003, 21:59
Default How to modify velocity with UDF
jddmsh
Hi, everybody! I need to modify axial velocity to be reversed immediately in a unsteady system. I used the coupled solver. So before flow velotity vector being reversed, I set the time step as 0.0000001s, and the number of time steps is 1, the max iteration per time step is 1. after this, I complied my udf, it is: #include "udf.h" DEFINE_ADJUST(x_v,d) { Thread *t; cell_t c; thread_loop_c (t,d) { begin_c_loop (c,t) C_U(c,t)=-C_U(c,t); end_c_loop (c,t) } } But after iteration,I found the velocity was not reversed. I changed C_U(c,t)=-C_U(c,t) with C_U(c,t)=-C_U_M1(c,t), but the result is not changed. Anany body?
UDF paraboloid velocity inlet rosco FLUENT 10 June 2, 2017 08:01
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 18:29
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 06:47
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 12:20
